Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Gelcoat stained rust spot. >
Old 05-19-2020, 08:03 PM
scippy's Avatar
Default Gelcoat stained rust spot.
Gelcoat under rear bench seat was stained from rusted hardware (non SS staples and nuts & bolts) Apparently, water saturated the upholstery & padding
causing a lot of the wood bench seat to rot along with rusted metal stains on the gelcoat below.......looking for a quick fix ....Paint???....or can I just brush on
white gelcoat to cover?
scippy is offline
Old 05-19-2020, 08:30 PM
scippy's Avatar
scippy is offline
Old 05-19-2020, 08:31 PM
scippy's Avatar
scippy is offline
Old 05-19-2020, 08:55 PM
I would try a strong solution if Iron Out and see what happens. I know I use it on our hull for the yellow stains
3pointstar
3pointstar is offline
scippy (05-20-2020)
Old 05-19-2020, 09:08 PM
Have you tried a cleaner like Starbrite Rust stain remover?
speicher lane is offline
scippy (05-20-2020)
Old 05-20-2020, 01:29 AM
Muratic acid, Sno Bowl or Works toilet bowl cleaner.
Griff is offline
Gimme Fuel (05-21-2020)
Old 05-20-2020, 12:42 PM
scippy's Avatar
I tried muratic acid with a bristled brush last night although it cleaned surrounding top coat, it's pretty much the same as seen in pic w/deep seated rust stain
in gelcoat..........option now is to cover. My question is, can I just brush on white gelcoat to cover stain? -or- what type of white paint bonds good to gelcoat?
scippy is offline
Old 05-20-2020, 12:52 PM
Try Whink Rust Stain Remover. Itís available at most local hardware stores and the big box stores too. Iíve been using it for super tough rust stains for over 25 years. Works on gelcoat, ceramic, porcelain, you name it. Itís hydrofluoric acid so itís different than CLR and some of the others. All I can say is it has shocked me how quick and effective it is on countless ditch hope occasions kind of like yours. Itís only $5 too.
Baja_260 is offline
scippy (05-20-2020)
Old 05-21-2020, 05:20 PM
I would try on and off hull cleaner ,it's made by marykate. We keep it in stock , find it at most boat places. hf...
halffast is offline
scippy (05-23-2020)
Old 05-22-2020, 06:40 AM
I would paint as last resort. These acid recommendations will work at some point
fossil fuel is offline
scippy (05-23-2020)
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
