-   Fiberglass and Paint (https://www.offshoreonly.com/forums/fiberglass-paint-167/)
-   -   Hole removal (https://www.offshoreonly.com/forums/fiberglass-paint/371317-hole-removal.html)
zz28zz 04-23-2021 08:19 PM
Hole removal
Prev owner installed custom eng oil drains that exited the bilge thru 2 holes drilled abt 3" left/right and above the drain plug. It never worked well and since I have an eng out, I'm wanting to remove the holes. I've been thru a similar procedure once when I installed ext steering. However this time I want to apply gelcoat after epoxy dries to really make the holes disappear. When filling the hole with epoxy, should I bring the epoxy all the way out to the surface (then sand) or stop a little short to allow room for gelcoat? How thick should the gelcoat be over the old hole? This will be my first experience applying gelcoat.
I used West Systems six10 epoxy last time. It had a mixer nozzle on the end of tube. Worked very well. Is there something better I could use?
Thx!
outonsafari 04-24-2021 07:22 AM
https://www.offshoreonly.com/forums/...ing-holes.html
https://www.offshoreonly.com/forums/...ash-holes.html
https://cimg6.ibsrv.net/gimg/www.off...35b7b19ec4.jpg
https://cimg7.ibsrv.net/gimg/www.off...dc89329629.jpg
https://cimg8.ibsrv.net/gimg/www.off...39553ca5a5.jpg
https://cimg3.ibsrv.net/gimg/www.off...bf0cc16fd0.jpg
read up on the subject, read some more, get your materials all sorted out, prep the holes really really good.
Cut your dowels 1/2 inch shorter than total thickness and have a smaller dowel marked at 1/4 inch to drive dowels into position so both sides can get glass. Did mine this way and they have held up with no issues.
zz28zz 04-24-2021 09:09 PM
Got the old hardware out leaving holes abt 7/16" in diameter. Ran a 1/2" drill bit thru the holes and hit good clean wood.
I like the dowel pin idea and I know pine is out. Any recommendations on type of hardwood or would fiberglass dowels better?
Rookie 04-25-2021 09:42 AM
Oak dowel at Home Depot and why not just use polyester or vinylester resin?
zz28zz 04-25-2021 12:58 PM
I'm a newbie when it comes to glass work. I usually farm out any glass (or body work on cars) to the pros.. Never used either resin before. What little work I have done with glass I used epoxy. Seems there are about 1/2 dozen ways to skin a cat, but I'm just wanting to use whatever method will protect the transom best and look good.
Rookie 04-27-2021 07:20 AM
I was using West Systems also, but found with some glass mats that it really didn't wet out too good. (I believe 1708) The glue that bonds the 2 mats breaks down when using polyester or vinylester and allows the glass to get saturated. With the West System it didn't, seemed to leave a barrier. I don't believe the glass was ever fully saturated and was seemed weaker. I never had the gelcoat adhesion problems others mention when using epoxy. Just some info I wanted to pass along.
zz28zz 04-27-2021 07:10 PM
Good to know abt the wetting properties.
Which type resin would work best for this repair?
Do I need to place glass in the hole like is shown above? It's only a 1/2" hole but I believe I'm supposed to grind away a little more on the outside to remove any tiny cracks in existing gelcoat from drilling.
Tractionless 04-29-2021 05:04 PM
Wow they made more holes in the transom just to drain oil? :picard1: Most leave the hoses laying in the bilge then feed each out of the bilge drain hole when needed.
zz28zz 05-01-2021 10:42 PM
The oil drain fittings have been bugging me ever since I got the boat. They didn't really work. Took abt 24 hrs to drain the pan.
Picked up up some oak dowel today at home depot. They sell resin made by Bondo. Wasn't sure if that was the best choice or not so I passed. Tried finding a place that sells fiberglass repair supplies but no luck finding anything local that's still open. Called around looking for someone to come out to my place to do the repair, but no luck there either. The epoxy method is looking better and better.
Tractionless 05-02-2021 08:04 AM
Wow that's a long time for gravity drain, thought my West Marine vacuum took long at 1.5 hrs.
Copyright 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
