-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Speed Formula 382 fastech (https://www.offshoreonly.com/forums/formula/102206-speed-formula-382-fastech.html)
Toffen 05-02-2005 11:52 AM
Hi!
How fast will a Formula 382 Fastech run with
2 x 525 HP engines
2 x 600 HP engines
2 x 650 HP engines
A 1998 model with 2 x 415 HP (502 engines) is for sale in Norway for an affordable price.
An engine builder in my hometown can easily rebuild those engines to 525 HP each without compressor.
Cheeers, Toffen G :rolleyes:
Formula Outlaw 05-02-2005 04:40 PM
Re: Speed Formula 382 fastech
Originally Posted by Troutly
I'll take a stab.
Assuming it is a loaded out boat (gen, full cabin, full fuel, couple of geeks on board) and it has Stellings boxes...with not much tweaking done.
525's = approx 79 MPH
600's = approx 83 MPH
650's = approx. 86 MPH
Give or take a MPH or two...
382's are heavy and need power to make them run.
Now are those speeds with, or without, donuts...:D :D
Toffen 05-02-2005 04:40 PM
I'll take a stab.
Hi!
Thanks for swift answer.
The problem when buying a second hand Formula 382 Fastech from US is Norways import taxes...:
Fx price Formula 382 FT with twin 500 EFI's = USD 150.000,-
Engine tax = USD 20.000,-
Transport from US = USD 10.000,-
Value added tax 25% = USD 45.000,-
Sum = USD 225.000,-
USD 225.000 is equivalent to NOK 1.425.000,-
This sum often apply to a Formula 353 Fastech too...
This Formula 382 Fastech 1998 model is for sale for NOK 895.000,-. Typically NOK 850.000,- cash.
So you have some money to upgrade the engines locally...
Those taxes, those taxes... :(
Cheeeers, Toffen G :D
Formula Outlaw 05-03-2005 05:49 AM
The donut factor is the "give or take a MPH or two" :D
Ahaaaaa, just what I suspected......:drink: :D :D
t500hps 05-03-2005 07:11 AM
MAN those taxes are killer. You could have an engine(s) dismantled, shipped in parts, and then reassembled for less than the $20,000.00 tax. Consider buying a bare hull and claiming it's worth 50k..... :eureka:
Toffen 05-03-2005 10:41 AM
Hi!
Yes, there is a possibility to dismantle the engines and import them as carengines, not paying HP tax. And then buy a second hand hull with "display" price.
Cheeeers, Toffen :drink:
Toffen 05-21-2005 06:26 AM
Hi again,
How much horsepower can a Bravo One outdrive handle? 550 HP?
Cheeers, Toffen G :D
RedDog382 05-21-2005 07:35 AM
Originally Posted by Toffen
Hi again,
Toffen,
Depends on three things ... the weight of the boat, how hard you drive it, and how good you are pulling back on the throttles when you get air. I ran a Formula 311 with 645 H.P. motors for 4 years and never had a problem with standard Bravo 1's. The 382 with 645 H.P. will be much harder on the drives due to the extra #3000 lbs weight difference.
