-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   242SS bilge drainage . . . (https://www.offshoreonly.com/forums/formula/103194-242ss-bilge-drainage.html)
tpenfield 05-15-2005 05:42 AM
I'm still getting familiar with my *new* 1991 242. I took the raw sea water pump out yesterday for impeller inspection. Lots of 'fun'.
Anyway, I have noticed some water in the well in the cabin and some in the engine bilge. The cabin well (call it the mini bilge) will drain into the main bilge when the bow is raised slightly. As I work on the boat, and raise/lower the bow for various things, I notice that water keeps re-appearing in the cabin well.
I originally thought that the water from the cabin drains to the engine bilge by a hose that goes over the fuel tank, making it difficult/impossible for it to flow back to the bow. It seems that this is not the case, and that perhaps the two bilge areas are connected closer to the keel of the boat (i.e. by a hose that goes under the fuel tank).
Any insight to the plumbing on this boat would be appreciated.
Much thanks.
ThirdBird 05-15-2005 07:30 AM
Re: 242SS bilge drainage . . .
There was some pretty extensive discussion on this topic a few weeks back, do a search, you'll find it. Bottom line - the engine bilge does communicate with the cabin bilge via drainage system along the keel under the gas tank. Supposedly, Formula included plugs for the cabin bilge. Some guys have theirs, some don't. Mine are (is) gone. Gotta get a plug to stop this drain-back situation.
88formula223 05-17-2005 09:19 AM
I found my two plugs in the owners manual bag, they look alittle big from what I've read here they are very small holes, when I get the boat back from pressure testing the tank I will see if they fit. I was getting a gas smell in the cabin, but it might be from a hose in the engine compartment, then running into the cabin from the undertank plumbing. I hope its not the tank $$$$ anyone know if they can repair the tank if there is a problem with it?
thanks PJ
I know there isnt a lot of 223's on here, but if anyone needs any info from the owners manual of a 223ls I'd be glad to scan it and email it to you
ThirdBird 05-17-2005 11:32 AM
Those larger plugs you found may be the Silent Thunder platform plugs. Look under your platform, you'll see two holes approximately 5/8" diameter near front of platform (toward transom). They keep the water in the platform for sound muffling purposes.
If you smell gas, that's not a good thing. Most likely means tank has a leak. Could be a line but,,,,,,,,,,,,,, probably the bottom of the tank. :(
Poorsche 05-17-2005 11:36 AM
I have an SR357--get the same odors sometimes--they come thru the bilge compartments. I also have the problem with the water to the step under the step. It comes from the bilge when the bow is lower than level.
I haven;t found the holes that need plugged but everyone else seems to ahve found them.
Good luck--there were a lot of posting aboutt his in last few weeks in Formula forum.
88formula223 05-17-2005 01:04 PM
AHH...now that I think about it you are right they are the platform plugs, don't need them drilled a buch of holes in the bottom to get that water out of there. I don't think there is a problem under the tank because its not all the time, it only is present when there is water under the step. Anyone just fill in that whole under step bilge area in with something??
Thanks PJ
anyone need those platform plugs you can have them
Poorsche 05-17-2005 02:39 PM
I got some ffedback that the Vacuflush components are installed in that step area. It's the only way to get the vacuum pump lower than the "terlet".
Mine used to have the condensate from the A/C drain there. I got rid of that nistiness by installing a"Condensater" from Mermaid Marine A/C. It works geat--would highly recommend if you;ve got A/C installed.
Old floating bird 06-01-2005 02:21 PM
Re: 223 Manual???
You say you have a manual for that?
(I'm guessing you really meant 223 and not 233)
Anyway, I'd love to have a copy or real thing...(I figure even if it is for a 223ls, it's better than what I have now...)
Thanks!
OFB
88formula223 06-01-2005 04:10 PM
you have a fax machine? I'd would be glad to fax it to you, if not it will take me a bit to scan it and email it, either way let me know ill get you a copy as soon as I can. it is a 223LS
PJ
CMG 06-01-2005 08:22 PM
Call Chuck @ Formula, he knows everything - call and if unavailable leave a voice mail with a description what info you need. 260-724-1412
He's a nice guy / good luck
