382 battery charger???'s
I pulled the boat to the lake yesterday and only had juice to barely start the engines. When I pulled it back into my shop and hooked up electricity, the battery charger was not working. Is there any fuses or breakers anywhere that would affect this or is my charger shot?
Thanks Corey |
Re: 382 battery charger???'s
See Too Olds thread about electrical power,lots of breakers and switches on a 382
If I remember correctly, there is a small flap door on the lower end of the face of the charger with a fuse (or fuses). Also check under the seat starboard side for main shorepower breaker, port side for battery switch and accessory breaker.
If you can't find the problem, PM WAGS382 ... he had a problem with his charger and is good at troubleshooting things like this. |
Cool, I'm going to play around with the charger some today and see if I can fix it, if not I'll try WAGS.
Thanks Corey |
| All times are GMT -5. The time now is 10:38 AM. |
