-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   prop suggestions 312 fastech (https://www.offshoreonly.com/forums/formula/120455-prop-suggestions-312-fastech.html)
mikesonic 01-14-2006 07:08 PM
I have 312 fastech 1998. I put two new engine 500hp carb. I have bravo 1 gear 1.65. I want to know if anybody have suggestion for the prop set up. Thank you! :chimp:
t500hps 01-14-2006 07:18 PM
Re: prop suggestions 312 fastech
Lucky bastard :D .....I've got the same boat/drives and want the same engines. Can't answer your question but I am running 30P 4 blade bravos with 415 HP 502's. Guessing 33P/34P
mikesonic 01-14-2006 08:25 PM
500hp what your speed with 502 415mpi thank.
t500hps 01-14-2006 08:52 PM
The boat had some chips/gouges in the bottom and "bad" props last summer when I got it. I rev 5000 and see 72/73 GPS regularly. Hope to get 1-2 more since the bottom and props have been fixed in the last few weeks.
Island Hopper 01-19-2006 12:16 PM
I think the problem you are going to have with that gear ratio, is not enough prop. You may need to concider changing to a 1:50/1. With that you may be at a 32, otherwise I think you will be at 34 or better.
