Formula door squeaks??? (where's Magicfloat)
The cabin door on our 312 squeaks while underway. Seems a little chop makes something rattle and I can't duplicate it while at home on the trailer. I believe one of the plastic "runners" that are attached to the bottom of the door is missing. The door also seems to have some up and down play at the rear of the door suggesting the problem is here. Could that be it and how in the world do you remove the door to replace that runner???
Russ C. |
Re: Formula door squeaks??? (where's Magicfloat)
Ttt
Direct from Formula TAG "If a runner is missing it could cause a squeak.You don't have to remove the door to replace them,you just need 2 people to do it. They are held on with 10/24 bolts and nylock nuts.lower sliders $46 each. Upper $15 each,there are 2 upper and 2 lower."
Thanks Robert, Russ C. |
| All times are GMT -5. The time now is 11:26 AM. |
