project ...... >
project ......
project ......
Old 02-24-2006 | 07:08 AM
  #51
Audiofn's Avatar
Charter Member #232
Default Re: project ......
River Rat probably a good idea......
Put your best foot forward!
Audiofn is offline
Old 02-24-2006 | 03:56 PM
  #52
wantsa311's Avatar
I"m Not Gonna Look ...
wantsa311 is offline
Old 02-24-2006 | 08:42 PM
  #53
offthefront's Avatar
OK new plan ... after looking over the situaion .. we drilled a test hole in Starboard stringer ...about 12" from the bulkhead end .... mush ... So on tomorow the plan is to make a template for the motor mounts ...piece of plywood with holes for the inner transom assembly to the front motor mounts. Also going to measure from a straight edge to top of the motor mount brackets ... we're going to try and make a template of the stringers too ..... then cut em all out ... It was going to cost almost 1000.00 for the seacast not counting the outside stringers . I can do it less with plywood. I talked to one of the best shops around here and they said to use Fir plywood instead of marine ....
offthefront is offline
Old 02-24-2006 | 09:52 PM
  #54
jeff32's Avatar
I'll look at your picture... so I can do mine!
jeff32 is offline
Old 02-24-2006 | 10:22 PM
  #55
Audiofn's Avatar
Charter Member #232
Why did he want Fir over Marine?
Audiofn is offline
Old 02-25-2006 | 06:57 AM
  #56
he said it "wasn't Pine" ... still has exterior glue ....gona do some more asking ....
Old 02-25-2006 | 05:15 PM
  #57
Formula Outlaw's Avatar
Gonna start calling you "Little Jon"....
What a quagmire....
Formula Outlaw is offline
Old 02-25-2006 | 06:15 PM
  #58
Audiofn's Avatar
Charter Member #232
What a quagmire....
His boat is bigger then mine!!!!!
Audiofn is offline
Old 02-25-2006 | 06:16 PM
  #59
Audiofn's Avatar
Charter Member #232
I used Okume (not sure of the spelling)
Audiofn is offline
Old 02-25-2006 | 06:19 PM
  #60
Audiofn's Avatar
Charter Member #232
This is were I get my Marine wood. Some info that may help....
http://www.boulterplywood.com/
Just click on the marine plywood.
Jon
Audiofn is offline
