-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Gauge Question (https://www.offshoreonly.com/forums/formula/121895-gauge-question.html)
88formula223 02-05-2006 02:05 PM
Gauge Question
What All Is Involved In Chaging The Guages, Do The New Ones Just Hook Up To The Old Wires Or Are Their New Sensors To Be Put In?? I Want A Gps Speedo Probly Livorsi, Where Do I Get The New Dash Panel?
Thanks Pj
mopower 02-05-2006 10:14 PM
Re: Gauge Question
1 Attachment(s)
VDO guages for Formula are European and some of the senders work backward as compared to American guages , fuel sender being one of them. I already did this change. I think the oil pressure was backward too. Here I am the first time out with a full tank. The farther I went the fuller it got :rolleyes: .
RedDog382 02-06-2006 01:28 AM
Re: Gauge Question
Fuel sender needs to be changed. I believe oil and water temp senders are compatible. Check with tech at Livorsi or Fred at Trick Marine, they will both be able to tell you what you need.
88formula223 02-06-2006 04:41 PM
Re: Gauge Question
thanks
