-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Silent Thunder question (https://www.offshoreonly.com/forums/formula/123597-silent-thunder-question.html)
PierPressure 02-27-2006 07:59 PM
Has anyone ever routed exhaust pipes through the Silent Thunder platform so they connect to the pipes coming out of the transom? I've got one for an 87 206LS which I took off due to drag and rattles. Any ideas?
Iggy 02-28-2006 05:21 AM
Re: Silent Thunder question
Read this thread..... http://www.offshoreonly.com/forums/s...silent+thunder
PierPressure 02-28-2006 12:39 PM
Thanks!! That is exactly what I was looking for. It looks like a few fabricated pieces and standard exhaust hose. Sounds easier said than done. This may be a side project.
Iggy 02-28-2006 02:03 PM
If I remember it right, he had to have custom tips made for the outlet ends (the square tips). I don't recall all he did to complete it. Try searching or any other threads by him.
offthefront 02-28-2006 03:06 PM
I dont think I ever heard how it worked out ....
PierPressure 02-28-2006 05:24 PM
I spent some time searching old postings today and I found a lot of info. Check these out and see if it sells you. It looks like Ramb. originally drilled some holes through the baffles to add a little noise. Later it appears his boat sprouted wings and busted the platform when it landed. From here I think is when he went with the routed pipes. I'M SOLD!
http://www.offshoreonly.com/forums/s...ad.php?t=32207
http://www.offshoreonly.com/forums/s...=102204&page=2
http://www.offshoreonly.com/forums/s...d.php?t=102204
http://www.offshoreonly.com/forums/s...ad.php?t=24359
masi242 02-28-2006 06:32 PM
1 Attachment(s)
I am working on this same project and I just got some new tips in for a diffrent look. Tell me what you think. I am going to use a coragated exhaust hose so it will bend inside the platform. I`m using a dremal to cut the inside it works great.
PierPressure 02-28-2006 07:10 PM
Looks good, I guess your putting flappers over that tip? How much does that piping cost? I read in one forum that flexible exhaust hose runs around $1.75 per inch! Yikes. Are those tips the same size as you would find on the transom? How did the square to round transfer go?
PierPressure 02-28-2006 07:11 PM
Disregard the flapper question. I finally opened my eyes and saw the internal flapper in the close up.
Iggy 03-01-2006 01:19 PM
I'm leaving mine alone. I like it just the way it is.
Well, maybe I'll cut the baffles out.
Beyond needing new transom and exhaust seals it's just fine.
