-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   382 questions (https://www.offshoreonly.com/forums/formula/123608-382-questions.html)
Maritime_Eng 02-27-2006 10:16 PM
382 questions
Hi All-
So now that the boat is home it is time to start fixing the little problems and upgrading others. I have a few question for the formula experts!
1) I am looking to remove the silent thunder box. Are the four four bolts that hold on the box through the platform or are they held on with threaded inserts? Can the box be reomved with out having someone inside the boat?
2) The passenger seat and foot rest do not move. I have checked the breaker and it is working properly. I have also tested the switches and they are also functional so I am thinking that it is either a power supply problem or both motors are bad. With the seat down how would you remove the rear planel of the bolster to expose the motor? How does the fooot rest come apart to test the motor?
3) Last the remote (touch pad) for the Kenwood stereo does not work. Does this remote require batteries. Has any one else had this problem?
Thanks for all of your help
Don
t500hps 02-28-2006 05:45 AM
Re: 382 questions
Don,
There are several threads on here about removing the silent thunder box....I just did mine 2-3 months ago. The 4 bolts and then it's wedged in there.
For the seat, lower the seat if you can and get behind the bolster, there are 6-8 screws to remove and then you can start pulling the bottom section down (it's pretty easy)
For the footrest, pull up the padded grey material that is glued down on the foot pad, behind it is a 4-5 inch round access hole with 3-4 screws. Once that round plate is removed you'll see the motor.
For the stereo.....don't have it, can't help you. :rolleyes:
Audiofn 02-28-2006 07:28 AM
Re: 382 questions
The remote does not require batteries. I know lots of people that have had issues with those remotes.
Jon
Maritime_Eng 02-28-2006 11:23 AM
Re: 382 questions
Originally Posted by t500hps
Don,
Thanks! I will be working on this on Saturday.
Maritime_Eng 02-28-2006 11:24 AM
Re: 382 questions
Jon
AudioFN, thanks for the info. Is there a replacement that works better or a way to fix the one I have?
