Fastech / SC5000 / Depth finder transducer
Is anyone out there running the SmartCraft SC5000 in a Fastech and using the depth finder option? Formula does not install the transducer to be used with the SC5000. I got the Mercury part number for the correct transducer (888828-1). I believe it will plug in the harness at the engines since there is a plug labeled "depth finder" back there, but was wondering the best place to mount the transducer. Not sure if the if structural grid liner in the Fastech hulls would allow a clear signal for a thru-hull type depth finder. Thanks for any help. :drink:
Re: Fastech / SC5000 / Depth finder transducer
It should be right in front of the 1st step, however, under high speeds in may not work well due to the stepped hull.
Ted. |
2 Attachment(s)
This is a for a sounder on a 370.
Thanks tc4542. I don't have any information other than the part number for the SC5000 transducer, but I assumed it is the type you epoxy to the inside of the hull and the signal travels through the hull. The type in your picture looks like it actually requires a hole through the hull. Is this for the SC5000? Do they offer the other type?
I'll tell you, I am really having a hard time finding good literature or anyone who really knows the SC5000. The manual I got from Formula (MerCruiser's) really just cover the basics. MerCruiser really needs to spend some time educating their dealers and technicians on this stuff... |
| All times are GMT -5. The time now is 10:09 PM. |
