-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   my nemesis=====black dash (https://www.offshoreonly.com/forums/formula/129778-my-nemesis%3D%3D%3D%3D%3Dblack-dash.html)
mopower 05-13-2006 07:05 PM
Re: my nemesis=====black dash
Originally Posted by Treads
MOPOWER, those panels look very nice. Where did you get them, or have them fabricated? Would like some info if you don't mind. :cool:
The guy who did mine did a GREAT job. Duplicated my originals except I had the pass. side done in two pieces istead of three pieces . Also redesigned the helm for oil temp , fuel pres. and water pres. Unfortunately due to health issues , Mark from MearImage has seemed to have fallen from the face of the earth :( :(
Maritime_Eng 05-13-2006 08:32 PM
Originally Posted by propwash
Hey Dgduck13, what did you do with the glass you took out of your boat? It is for a 311 right? When you removed the windshield did you have to support the glass and frame or was it self supporting? Thanks Propwash. Offthefront, nice job on that HUGH project of yours.
I ended up throwing out the glass when I made the move from MN to FL a little over a year ago.
The windsheild and frame are glued togther and is self supporting. When you remove the screws out of the bottom have a few friends around to help you carry the windsheild off of the boat. Otherwise you can take it apart in three pieces and carry them yourself. any other questions let me know.
Don
mopower 05-13-2006 08:40 PM
Where the screws be?? I heard they were above the headliner in the cabin :(
Maritime_Eng 05-13-2006 10:51 PM
You are able to access all the screws from the top side. Pull out the foam/plastic strip from the bottom of the windsheild frame. You should see all the screw heads. The only two you will not see will be the last bolt on each side by the air vents. remove the triangle air vents and you should see these bolts.
