-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   502 mag power curve? (https://www.offshoreonly.com/forums/formula/130248-502-mag-power-curve.html)
cstobe 05-15-2006 11:04 PM
I have a 502 mag in a 271 fastech that I have done some minor upgrades to. EMI thunder exhaust & EFI upgrade kit. Does anyone know at what rpm peak hp is made with the 502? I can spin a stock 26 bravo 1 to 5100RPM. Would I be better off trying to spin a 28 at lower rpm to stay closer to the peak hp?
formuladude312 05-17-2006 12:26 PM
Re: 502 mag power curve?
5000 rpm's is peak, top end tourque is around 3500
http://www.goautocenter.com/502_h_o_.htm
mopower 05-17-2006 03:40 PM
The 28 will increase your speed at 3000 rpms. So if your cruise more than run wide open it will increase your efficiency and mileage.
Magicfloat 05-17-2006 05:05 PM
Only way to know is to try a 28.But if you load the boat down with people and gear,getting on plane will be slow with the 28.Actually real slow :p Borrow a 28 and see.And remember, 271's use left hand props,if you borrow a right hand,just run it in reverse to test,no problem.
BAMSHEE 02-17-2011 01:19 PM
Did The Efi Upgrade Kit Help. What Kind Of Kit Was It
