-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Generator Surging (https://www.offshoreonly.com/forums/formula/130713-generator-surging.html)
dukenrock 05-22-2006 10:25 AM
Generator Surging
This is my second Formula that's had this problem. The generator surges after being run for 5-10 minutes. It's a factory installed Kawasaki generator. It starts and runs great for the first 5-10 minutes then begins to surge real bad.
PhantomChaos 05-22-2006 10:34 PM
Re: Generator Surging
Sounds like the choke is sticking.........open the hatch and mess around with the throttle stuff.....
Iggy 05-23-2006 04:57 AM
Could be something wrong with the engine RPM governer too.
For that you may need to contact a service tech.
dukenrock 05-24-2006 10:45 AM
I'll look and see if the chocke thingy and if not, off to a pro!
C_Spray 05-25-2006 09:13 AM
I had the same issue with my (factory) 5kw Onan. Replacing the fuel filter didn't help, but changing the spark plugs worked like a champ. Most generators get run under too light a load, and tend to foul up the plugs.
dukenrock 05-25-2006 09:43 AM
I think you could be right! I'll give that a try.
plumbers crack 05-25-2006 05:27 PM
My generator was acting up and the mechanic told me as soon as the engine starts running rough,change ou t the plugs first!
C_Spray 06-13-2006 01:06 PM
Dukenrock - What fixed it in the end?
dukenrock 06-13-2006 01:48 PM
I haven't seen the boat since I posted! I hope to get to it this weekend. I'll let you know if the plug takes care of it.
