-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Water Temp (https://www.offshoreonly.com/forums/formula/130729-water-temp.html)
86formula242ls 05-22-2006 12:21 PM
Water Temp
I recently bght a 86 242ls and just had it out for the first time this weekend. Water temp gauge seemed very low. Anyway of testing to see if this gauge is accurate? Maybe my termostat is stuck open. Not sure.
mopower 05-22-2006 05:22 PM
Re: Water Temp
Maybe someone removed the t-stat :rolleyes:
ThirdBird 05-23-2006 05:48 AM
Re: Water Temp
Go for the thermostat first, it's the most likely culprit. Get the actual marine version. It has special gaskets that provide the proper ground.
86formula242ls 05-23-2006 12:02 PM
Re: Water Temp
Ok will do. Thaks t-bird. I am a new formula owner and this site is great. Thanks for all your help. I'll post some pics later.
RedDog382 05-23-2006 07:52 PM
Re: Water Temp
You want a 143* t-stat. water temps should run about 10* over that at highest.
