-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   hatch hinge...over or under???? (https://www.offshoreonly.com/forums/formula/132188-hatch-hinge-over-under.html)
88formula223 06-07-2006 07:46 PM
finally found a recommended shop to do the interior in a timely manner, does the hatch hinge go under the fiberglass shell so you could see the hinge when its open or on the top under the interior pieces so you can't see it??? I just want it done correctly !!!
thanks PJ
jeff32 06-07-2006 08:05 PM
Re: hatch hinge...over or under????
the hinges goes under the hatch and yes you can see them when hatch is open. But you have, underneath the foam of your hatch, a little piece of metal half inche by 3 inches, with 2 bolts that goes through the wood and also through the fiberglass of the hatch. So don't forget to put them back before the foam and your leather. I had the 2 bolts spot welded on the kind of metal washer so they would not turn inside the foam when I would screw the nuts underneath the hatch... Hope it helps...
88formula223 06-07-2006 08:41 PM
thanks Jeff, my memory was foggy I wanted to be sure
ThirdBird 06-07-2006 08:56 PM
Leather????? Really????? Didn't think cowhide would hold up to the sun and salt!! :p
88formula223 06-07-2006 08:58 PM
pleather
ljsmith1 06-07-2006 08:58 PM
"P"leather! :D
jeff32 06-09-2006 06:08 PM
sorry guys for that word. French speaking and I forgot the word upholstery, was searching not for the best word but just for any word that would make you understand, and that is the only one that came to my mind... use cushion if ever it's better!
88formula223 06-12-2006 12:42 PM
no problem Jeff just giving you a hard time thanks for the help
