Broke my motor!!
Hi guys.
I was out last night enjoying a few drinks while cruising at about 30mph when out of no where my motor starting making a loud popping noise from under the distributor cap area. Its a real loud banging/popping noise. Oil pressure was fine and motor temp was normal. Did I break a rocker arm or something? Any thoughts? Thanks guys |
Re: Broke my motor!!
How was the performance? I'm sure you immediately slowed down but did it still ide ok?
Originally Posted by 86formula242ls
Hi guys.
I was out last night enjoying a few drinks while cruising at about 30mph when out of no where my motor starting making a loud popping noise from under the distributor cap area. Its a real loud banging/popping noise. Oil pressure was fine and motor temp was normal. Did I break a rocker arm or something? Any thoughts? Thanks guys Crank the engine over and check for spark at the center distributor wire. If no spark, I'd bet its that module. Check it out, your problem sounds like what went wrong with mine. Hope it helps. |
I was going slow when it happened but the idle was fine after. It did'nt die on its own, just kept idling then I shut it off. I will check the distributor module.
Thanks guys |
You don't have an MSD do you? :rolleyes: :rolleyes:
Thanks guys |
Originally Posted by ThirdBird
Could be the distributor module. Mine went south over the past holiday weekend. When it went in my port motor, the engine banged, pinged, puked and shutdown real fast. I thought I blew the thing. After much troubleshooting and long distance technical assistance from Axapowell, turned out to be that module. It's in the bottom of the distributor, easy fix and cheap. Only about $55.00.
Originally Posted by RaggedEdge
Techinical assistance from the Senator ? Why you calling him ? He's an accountant , closest he gets to getting his hands dirty is if the old folks money has been buried in the back yard and still has dirt on the can when he gets his hands on it.
. He's not just another ugly accountant.
Rocker arm broke. Should be up and running in a few days.
| All times are GMT -5. The time now is 05:36 AM. |
