Formula's Rocker Switches
Ok guys, I know this has been discussed before, But the rocker switches for the trim,tariler and tabs ar junk, this will be th 4th one in a year, What other options are out there? Is there a better switch? I see that Too Old has some military rockers that are different colors which red ones would be nice, But does anybody know if they are the same as formulas? I know Honeywell had done the switches from i think 1999 and below, But who is doing them now? Thanks, Jeff
Re: Formula's Rocker Switches
1 Attachment(s)
Jeff,
First of all, I have the replacement covers which I ordered for my boat and found out that they were the wrong ones. I have 14 BRAND new covers. I will let them go at a discount! These are the ones that have 4 small holes (one in each corner) and nothing in the middle of the switch. The part number is 12PA5-W and they are white. Secondly, I replaced mine with Trick marine switches (see photo). I had to re-do my panel, but I think it was worth it. They seem to be working excellent. New this year, so I don't have a track record yet, only about 20 hours on the boat so far this year! Dave |
Dave, I saw you had those, Your panel is set up different then mine and those won't work as they are, My panel has 6 running down the right side 3 roes of 2, plus the depth guage and stereo remote on the left. Now if i could get a panel made and configured to meet my specifications would be great, I don't know who is out there that can fab a panel if i give them the specs, maybe even annodized or powder coated, Jeff,
Jeff,
Check you PM's. Dave |
Thanks for the help Dave, I will be in touch, Jeff
Hey, I know it's an old thread, but my switches are also now broken.
I need at least 1, ideally 2 new. Does anyone have the make/model? the switch cover has a plastic pin in the middle. (On the back side). or do I limp along until winter and have to redo the panel? thanks! |
Our part #3869: SWITCH ROCKER RS1001 BLK
Your cost: $79.55/Each + tax & shipping charges In stock |
| All times are GMT -5. The time now is 05:35 PM. |
