-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   How much does Silent Thunder weigh? (https://www.offshoreonly.com/forums/formula/133266-how-much-does-silent-thunder-weigh.html)
Grog 06-20-2006 02:49 PM
Formula guys -
I did some searching in this forum and couldn't find anything on the subject so I'll ask......
How much does the Silent Thunder box on my 1999 271 Fastech weigh? This is probably a baaaaad idea but I am thinking about removing it if the weight is significant.
Thanks,
Greg
offthefront 06-20-2006 03:52 PM
Re: How much does Silent Thunder weigh?
I would say 150lbs .... but also has water in it while under way ... FO removed his and thinks it the greatest thing since "Sliced Bread" ....but dont pay much attention to him...... :drink:
its EZ to remove .... you could try it ... I like the traditional look with it on ...
Treads 06-20-2006 04:08 PM
I would agree with offthefront, estimate between 125-150 lbs. Some variation can be expected due to glass thickness. The underside of the chamber on my 91 292 baries between 1/8" and almost 1/4", port to starboard respectively. I found this out as a result of a modification I did to relieve exhaust backpressure. Simply cut 3-1/4" holes on the underside (not visible unless your under the platform) of the platform, approximately 2" back from the transom. The sound did increase slightly :cool: more to my liking than the wife's, as well as allowed better drainage of water when running, thus reducing weight.
Just my 0.02
RedDog382 06-20-2006 06:35 PM
Mike,
I think he has the new style boat with the moulded in platform. The silent thunder just attaches underneath and you really don't see it like the older design.
t500hps 06-20-2006 06:46 PM
I have a 99 312 and the Silent Thunder box is completely different than the older SR-1 models you guys are refering to. I took mine off by myself this winter. 4 bolts and a little muscle and it was off. It weighed more like 60-70 lbs and although it carries some water while underway....it's not much. I like it much better without. I can hear the engines a little better and some of the rattles Formulas are know for come from that damn box.
offthefront 06-20-2006 07:51 PM
Originally Posted by RedDog382
Mike,
Yup my bad ....soooo I'd loose that puppy in a heartbeat ...But haven't I heard where its the Ladder rattling on the new platforms? Still ....drop that box ...
formuladude312 06-20-2006 09:23 PM
I agree with t500hp its no more then 70-80 lbs tops, I removed mine and went with ggb transom mount mufflers, So much better then with it on, It could probably get up to 125lbs when it is filled with water, Really no speed gain but better apperance and sound with the ggb's, 4 bolts and a 2x4 in one of the exhaust holes with a up and down pry and its off, It fits snug up under the swim platform.
Grog 06-21-2006 10:11 AM
Thanks for the input guys. 80# is substantial enough to consider removing it.
Is there any cosmetic (gelcoat) work that needs to be done that shows when the box is removed?
formuladude312 06-21-2006 10:26 AM
Just a good degreasing and waxing from the soot that will be behind there.
t500hps 06-21-2006 01:20 PM
After cleaning up (It's nasty in there) I had 1 small area where the box was rubbing under the swim platform. Left an area 1/2 by 1 1/2 inches that the gelcoat was rubbed down a little but unless you stuck your head under the boat and over the drives you really couldn't see it. When I had some bottom work done a few months later I had them fix that little spot since they had the boat anyway.
If you down like the boat without the box you can always put it back on......but I bet you'll never consider that once it's off!!! :drink:
gmgearhead454 02-07-2014 10:20 AM
I know this is a really old thread, but would any of you happen to know how much the OLD silent thunder swim platform weighs? I have an 89' 242ls and am removing it and putting on a nice tubular aluminum one, so light I can lift it with one hand! Just curious how much weight I'll be saving. Also Putin a 500+ horse engine in it while I'm doin that so it should run damn hard now ;)
offthefront 02-07-2014 06:02 PM
Post #2 still applies ....
kevlar382 02-17-2014 08:27 AM
You will want to fill the holes also from the bolts that held it on.
