-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Fuel lines 382 (https://www.offshoreonly.com/forums/formula/150366-fuel-lines-382-a.html)
dukenrock 01-30-2007 02:47 PM
Fuel lines 382
I installed a FloScan system and "spliced" the meter into the factory rubber fuel line between the tank and the fuel pump. I want to replace the rubber fuel line with a rigid line where I could make the appropriate bends. Reasoning behind this is so that the two Floscan meters would have a stable mount and I would make it so that it's easy to pull off the meter and meter prefilter. (I would want to use a type of union fitting) Has anyone done this and is it as good or better than the factory rubber hoses?
Rippem 01-30-2007 03:36 PM
Re: Fuel lines 382
stick with rubber. You're asking for trouble with hard lines. You didn't mount the sensors on their brackets?
replace the rubber line with enough length to run it along the back edge of the "floor" in front of the motors, secure with appropriate dia. cushion clamps into a couple of the existing screw holes for the trim on the back edge. Leave enough length on all hose to cut them if you need to for an annual replacement of the prefilters. You only loose about 1/2" of length if you have to split them and retrim for removal...so 1.5" of extra length on each hose gets you 3 annual changes IF you have to split them, before you need to replace a hose.
Been there done that.
I usually use a torch to heat up the hoses for easier removal :D
dukenrock 01-30-2007 03:47 PM
Re: Fuel lines 382
Rip,
I have the brackets installed but I don't like how they look so I want to redo them this winter. I wanted something where I could take out the prefilter or meter without cutting into the hose. (PITA) Even if I stick with the rubber fuel line (Which is OK with me) I would still like to utilize a union at the fuel line from the tank and another before it hits the pump for easy removal. If you have yours installed could you shoot me a pic of your hose routing? Thanks.
Kevin
dukenrock 01-30-2007 03:52 PM
Re: Fuel lines 382
Acetylene or propane?
RonS 01-30-2007 04:18 PM
Re: Fuel lines 382
If you want something you can remove without cutting use aeroquip fittings or something similar, maybe even braided lines and it will make it look a little more trick, the other problem with hard lines to the motor is when you run, the motors move more than you realize and the boat has a certain amount of flex to it which would be a problem with hard lines.
Rippem 01-30-2007 04:54 PM
Re: Fuel lines 382
Originally Posted by RonS (Post 2010295)
the other problem with hard lines to the motor is when you run, the motors move more than you realize which would be a problem with hard lines.
exactly my point.
route them any custom way you want, just use some rubber (push-lok) to AN adapters and custom plumb for easy R&R. Keep in mind you can get into leaky fitting bs also...It's hard to beat rubber on barbs and double worm clamps!
Just secure those sensors. They should be hard mounted for sure.
Now my engine rooms are clean for sure, but when it came to my fuel sensing installs...it's all about function and safety, very much less about form.
dukenrock 01-30-2007 04:59 PM
Re: Fuel lines 382
One more question...were you concerned about where the placement of the sensors were? (Higher than the fuel pump vs lower than the pump) I know the instructions indicated to install lower, but it really limits the mounting locations. I do like your idea of runing in front of the engines along the ledge. :drink:
Rippem 01-30-2007 05:13 PM
Re: Fuel lines 382
no. but I spec'd the "pulse traps" to install inline up high just before the motor even though they said they weren't necessary. helps with accuracy.
using the screw holes for the silver trim, and orienting the adel clamps "down" the lines are just below grade so you're not stepping on them.
ThirdBird 01-30-2007 06:01 PM
Re: Fuel lines 382
You should be careful with remarks like that, some idiot might actually use a torch.
er,,,,,,,,,,ah,,,,,,,,,, you actually did use a torch???
:evilb:
RaggedEdge 01-31-2007 07:04 AM
Re: Fuel lines 382
:evilb:
I've heard that he uses a Bic lighter to search for those hard to find fuel leaks. :eek:
dukenrock 01-31-2007 11:05 AM
Re: Fuel lines 382
Rip,
Do you recall the fuel line size? I'm an hour away from the boat and want to pick up some more fuel line and clamps.
Rippem 01-31-2007 04:39 PM
Re: Fuel lines 382
I wanna say 3/8 from the primary water seperator(s) that's back under the floor/backseat behind the tank, but don't want to steer you wrong.
James 01-31-2007 04:44 PM
Re: Fuel lines 382
I'm not sure what the flow limitations are of the flowscan units - The largest gas flow sensor I have seen is 45 gph, maybe that is all it will record accurately - you might want to look down the barrel to see if you have a true 3/8" bore. Some of these sensors will create .5 to 1 lbs restirction. from experience a loaded 525 WFO will burn 44-45 gph. If you have bigger you will need more pressure to compensate
Let us know what your specs are, drive and prop and fuel burn
Rippem 01-31-2007 05:10 PM
Re: Fuel lines 382
Flo-Scan makes 100 GPH sensors for consumer use, and much larger capacity sensors for the aircraft industry.
I wouldn't question the product too much, it's aircraft quality stuff. They are out of Seattle. What huge industry is right outside of Seattle?
Any idea why planes of many desciptions both civilian and military don't run out of fuel in the air?
It's not because they use the fuel gauges we have in our boats!
I believe he has the 50 GPH sensors.
dukenrock 01-31-2007 06:34 PM
Re: Fuel lines 382
I called Darrell at Formula and he said to get the 1" Adel's. (That's why I wanted the hose size..Guess I could have asked you for the Adel size) Picked up the adels today and will reroute this weekend. Just need to get some more fuel line and I should have everything I need. Thanks for the routing advice. (they are 50gph)
jenks 01-31-2007 10:15 PM
Re: Fuel lines 382
you know if your over 50gph why count?
offthefront 02-01-2007 04:44 PM
Re: Fuel lines 382
1 Attachment(s)
I'm using the Russell Nylon Braded hose on my motor rework ...nice stuff and can be reused and easy to remove ....Pricey but nice ..... Black .....
http://russellperformance.com/new/mc...-classic.shtml
dukenrock 02-01-2007 09:29 PM
Re: Fuel lines 382
That's what I was thinking of. I like.
