-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   speed/engine set ups (https://www.offshoreonly.com/forums/formula/152838-speed-engine-set-ups.html)
sleek1 03-04-2007 10:16 PM
Anyone know what kind of top speed to expect (realistic) from the following engines in a fastech 35? Assuming they're all propped the same pitch with 4 blades.
502MAG?
502EFI?
502HO?
axapowell 03-05-2007 12:29 AM
I would guess to say between 67-70, depending on your load, air, and temp...
Just a guess.
Dave
sleek1 03-05-2007 05:59 AM
R U saying all three engines would achieve the same top speed?
mopower 03-05-2007 06:07 AM
502 MPI and 502 Mag are almost the exact same hp(415). If you mean an HP500 by using the term "502HO" , that should get you a few more mph.
sleek1 03-05-2007 06:16 AM
I stand corrected... I meant 500HP's.
t500hps 03-05-2007 07:15 AM
A local guy has a 353/502 mag. Was told the boat would do 70-72 but claims 68 is the best he can get out of it. I would guess 500's would get you near 75.
axapowell 03-05-2007 09:55 AM
Thanks Mopower...What I was thinking and not typing...
As for the HP 500's Carbed, or EFI, you will be close to 77-80 mph, depending on the prop (labbed or not). All would be REAL numbers or GPS speeds.
Dave
Rippem 03-05-2007 03:32 PM
80 real MPH with 500's doesn't happen...period. I've been talking to owners since 2001.
77 and high change is pretty standard, right day, typically 1/2 load or less, FW, no boxes
unless you're on Smith Lake, Alabama :D
I've got the '02 Formula test report 353 w/ 500 EFI's here somewhere. I'll scan and post it if I can find it.
sleek1 03-06-2007 11:21 PM
What does FW stand for? Sorry.
Magicfloat 03-07-2007 02:53 PM
FW means fresh water,unless it is Smith Lake,Alabama,which in that case means fast water,he-he:D Actually,Rippem,we don't have faster water,we have faster drivers,cause we have to stay in front of the bass boats.:rolleyes:
