-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   112 volt power supply (https://www.offshoreonly.com/forums/formula/153986-112-volt-power-supply.html)
Magicfloat 03-19-2007 03:27 PM
I have a Kenwood marine stereo system installed in our boathouse. Need a reliable 110 volt transformer to power it . Used to use discarded plug in chargers from old 12 volt items,but they don't last long and don't supply quite enough amps. Last year I just hooked to a spare marine battery that I keep there for emergencies,and just charge it occasionally. Got to be a better way,something I can plug in to house current AC and step down to 12 volt DC. My local Radio Shack was no help.BTW,just noticed I said 112 volt in the title,I obviously meant 110 volt,but don't know how to edit a title:cool:
RedDog382 03-19-2007 04:17 PM
Robert,
My brother in Cleveland is a wizard with electronics. I will check with him and let you know his recommendations.
Chris
PhantomChaos 03-19-2007 04:17 PM
You need an AC/DC power supply and wire it in! Depending upon the power of the stereo......which I'm guessing isn't "ThisIsTank" size.....it shouldnt' be that big of a deal.
Probably a unit like this might work. You just have to wire it in.
http://datasheet.astrodyne.com/A-100F.pdf (model AS100F-12)
$76 dollars.....
http://www.astrodyne.com/astro/produ...ade=1&watts=53
Magicfloat 03-19-2007 05:39 PM
I'm pretty low tech,only 10 amps. My el cheapo plug in units would work until I crank up the volume. Most of them are only 1 or 2 amp,just to keep the batteries in cell phones and other junk charged,not really designed to run a stereo.
Rippem 03-19-2007 08:24 PM
careful...people walk into Radio Shack and are never seen again. :eek:
don't know how to edit a title :cool:
that's my boy! See RaggedEdge's sig line. :evilb: :D
PhantomChaos 03-19-2007 09:30 PM
That one I showed pumps 20 amps. Should be good enough to dance to.
