382 prop ??
I have 15.25 X 29's Labs on my 05, 525's Gen air. I think I'm a little steep. I'm seeing 76 @ 4700 wot. What should I step down to to see 5300 rpm. I'm a little slow coming out of the hole. Thanks
Are you running 4 or 5 blades?
29's??? Hydromotives?? I would look for 28 4 blade Bravos.
The lack of slip on a 5 blade causes good cruise speeds, but I'm concerned it also causes the drivetrain to snap when the prop won't slip. BTW: Formula loves the 5 blade maximas on their new 382's. |
5 blades
Originally Posted by 382 newbie
(Post 2120895)
5 blades
Example 26 hydro = to 28 bravo. |
mine are merc
Mine came with 26" 5 Blade Hydromotives. It gets out of the whole nicely but at 5300 RPM I'm lucky to see 74MPH with 3 people and full tank.
(Post 2120488)
Probably some Merc 5 blade 27's then. Should put you in the ball park.
| All times are GMT -5. The time now is 07:39 AM. |
