-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   DRIVES TRIM LEVELS 311 Formula TRS (https://www.offshoreonly.com/forums/formula/160564-drives-trim-levels-311-formula-trs.html)
saulesses 06-11-2007 03:04 PM
Hey Formula Owners would like to konw how har have you trim your drives while running I want to know basically the safe limit without things going wrong i Haved put mine up to 4 in the Kiekhaffer idicator.
Rambunctious 06-12-2007 08:52 AM
if you or soemone has a service manual , that should tell you hoepfully.
when you replace the "Puck " indicators on the bravo drives, the instuctions document the max extention of the bravo ram for safe/ relaible function and U joint life. I would think there is a similar spec for the TRS.
Ramb
