1995 Sr-271 Seat Removal
How Does The Rear Seat Come Out. I See The Bolts In The Engine Compartment That Come Thought, But Not Sure If There Are Any Other Hidden Ones Along The Side. Any Help Would Be Greatly Appreciated.
Thanks In Advance. |
Its a tough job, the sides are bolted in. You need to remove the grab handles and the trim panels under the grab handle. Then reach inside the side compartment with a offset ratchet screw driver and a big Phillips bit there is a few screws on each side. Then remove the cup holder/ step in the arm rest and I think there is a few screws in there to. The seat fits tight and is not easy to get in and out, if its wet and soaked with water you will need a helper
re
sounds like a good weekend project. thanks for the info!
| All times are GMT -5. The time now is 11:31 PM. |
