Circut Breakers
Where can I get the pull/push circut breakers that are in my formula? Its an 87 223 LS and its says E-T-A on the breakers. Thanks
Do a search breakers have been covered before.:ernaehrung004:
Try Custom Marine Services at http://www.cmsquick.com/
ETA circuit breakers were quoted to me at 55.00 ea. |
hey prosno call formula tech line and tell them what model boat and what breaker its for and they will tell you the amp and part number you will need . then call formula parts dealer. if more info needed let me know dave.
You go through Formula and you'll pay through the nose.
If you need to know what the part number is of a particular breaker, remove the panel and the p/n is printed on the side of each breaker. You may find that the basic p/n is the same for all your breakers except for the last two digits. Those are the amp rating. |
I found them at Ocean Performance, $29.00 each. We ended up needing 3 of them so it got a little pricey but hey I guess thats the cost of boating. Thanks guys.
I dident buy breakers from formula.i just got part numbers from them. i called passport marine fl. paid 18. for one and 22. for other
re: circuit breakers
I replaced all of mine a few years back. I got them from Wes-Garde Components. They were exact replacements and much cheaper then through Formula. The site is www.wesgarde.com or 1-800-554-8866
I hope they are still there. This was about 3 years ago. |
| All times are GMT -5. The time now is 02:37 PM. |
