repowering 242ls
Hello can anyone give me any advice, I have a 1989 formula 242ls which is currently powered by a 454 mag 7.4 335hp which i have stripped to the block and will completely rebuild with bravo 1. I would like more hp but not sure which parts to upgrade. Does anyone know if its possible to re-bore to 502 ci.
Any advise would be much appreciated thanks. |
Originally Posted by formula 69
(Post 2382960)
repowering 242ls
Hello thanks for the reply, no am not a member of sw, sorry got the horse power incorrect it is 365 hp. I run my boat in the channel islands its a group of islands in the english channel between france and england.
I dont have bolster seats but have been looking out for some i have just the captains chair type ones at the moment. |
Can't bore a 454 to 502:(. But you can replace the crank with a 4.25 stroke and get 496 cu in.
repowering 242ls
Hi thanks mopower do you know if you have to change the cam pistons and con-rods to if you upgrade the crank to a 4.250
To get 496 , I believe that is a +.030 on the bore also so new pistons would be required. Both Scat and Eagle make stroker kits with H beam rods and forged cranks at reasonable prices.
Why not change the cam for more performance while your at it. It sounds like that is what you're looking for anyway:cool-smiley-011: |
| All times are GMT -5. The time now is 09:25 AM. |
