311 Engine Question
Are both engines in a stock 311 "standard rotation"? What is actually different between a standard and non-standard besides the obvious rotation direction? Can you tell by looking at the cam or crank if it is one or the other?
If they are both standard rotation, how do I end up with counter rotating props? Is it in the outdrive somewhere? |
Originally Posted by wantsa311
(Post 2576059)
Correct, rotation is contolled in the outdrive.
Some inboard 454's were counter-rotation. Mostly in big cxabin cruisers. I have a pair of 427 Ford motors from a Chris Craft and one of those runs backwards too. I don't think any sterndrive application Big Blocks run backwards
Originally Posted by spazboz
(Post 2577443)
How about TRS drives, does the counter-rotation happen in the tranny or in the outdrive? |
(Post 2576059)
If they are both standard rotation, how do I end up with counter rotating props? Is it in the outdrive somewhere? Bob ..... The Bravo drives will rotate in either direction ....to counter rotate one drive is in Reverse ..... seems its done at the controls ....where the cables are attached ....m |
Originally Posted by ThirdBird
(Post 2577656)
Right you are! Most older inboards had counter-rotating engines.
| All times are GMT -5. The time now is 09:30 AM. |
