-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   311 pics (https://www.offshoreonly.com/forums/formula/193581-311-pics.html)
Car Biz 08-20-2008 05:57 PM
311 pics
3 Attachment(s)
I thought i would post some pics for everyone. Still tring to get it proped right but it is nice to be able to enjoy it alittle:drink:
masi242 08-20-2008 06:10 PM
I`m sure it`s nice to be out, I know you have gone through alot.
Good luck
Rambunctious 08-20-2008 07:16 PM
sweet Jeremy !!
did you try higher pitch props yet?
Ramb
vrodn 08-20-2008 08:32 PM
Good to see you're in the water.
88formula223 08-20-2008 09:51 PM
lookn good biz glad to see you in the water
ThirdBird 08-21-2008 06:00 AM
Nice 311!!!
got twins ? 08-21-2008 08:28 PM
:ernaehrung004:
What a great looking 311 .... love the rooster ......
Noth'in better then our ole hot rods .....
We need to get all the 311s from the north east together for a weekend .....
Jeff
Shameless 08-21-2008 10:34 PM
very nice!!
Car Biz 08-25-2008 07:26 AM
Originally Posted by Rambunctious (Post 2658870)
sweet Jeremy !!
Ramb
Thanks guys. it is a fun ride.
Ram- The props tha tare on it rite now are 17X30 3 blades i borrowed from Josh. I can still spin them 5200. I did gain a couple MPH. I still have WAY to much slip. It will be a process. but i will get it right!!
Rambunctious 08-25-2008 08:07 AM
do you think the x dim is not setup right?
what was the speed with the 30's at 5200?
what did josh say
Ramb
Perfectmix 08-26-2008 09:58 AM
I have been thinking about this and can't quite figure it out. My 311 Kaama ran 65 with 375hp/torque? spinning 16.5X26 4 blades at 5000. The 30's I had would not even work on my boat. Doesn't sound like you have found the right prop yet. You need to find a set of 16.5X26 4 blades and I bet your boat would wake up. Bring it up to Torch Lake. My old 311 is still here and I could snag the props off of it to try on your rig. Glad to see you up and running.
Rambunctious 08-26-2008 10:18 AM
It would be great to compare the two boats
Jeremy has different mounting plates on the transom I think, possibly resulting in a different x dimension?
the gear ratios could be different between the two boats ?,
and it would be good to compare the trim settings ( drive angle vs. indicator position)
EDIT - and a pic of the two boats with their rooster tail would be Formula Inc. archive worthy !!
I wanna come too :D
Ramb
Car Biz 08-27-2008 08:25 AM
I wanna come too :D
Ramb
I think the next step is to check the drive to make sure that it really is 1.1. From what i can read on the tag( was painted over) it says 1-1 but i want to check it.
I have thought about the X but if it was higher the boat should be faster. With the big transom plates the drives would be mounted higher. The only thing that could solve that is a BIG diameter wheel Right?........
Josh- i will give you ring today i will be going up there for a wedding in Oct.
Rambunctious 08-27-2008 08:37 AM
october...Torch lake will be frozen over by then :evilb:
rotating the crank 10 times and counting the prop rotation could confirm the overall ratio. should be 1.5 with tranny and drive combo right?
and +/- up to 20% from that if gears are changed?
Ramb
Car Biz 08-27-2008 08:42 AM
Ramb
Correct. But if i spin the prop one revolution the H-bar inside the boat before the trans should spin one revolution. If it does not then i need to find out how much -/+ it is in the drive. it could be any where from 8 to 20.The trans are 1.54
jaybird 08-27-2008 08:50 AM
Looks good! Glad to hear she's up and running. Hopefully it won't take too long to get it dialed in. Makes me wonder what my 311 would have done if I had done some serious prop exploring...
Car Biz 09-03-2008 07:44 AM
Well i tried a pair of 17x29 4 blades mon and oh boy!!! 67.9@4800 with 5 people and 3/4 of a tank at 0 trim. It is time to make a solo run with full trim and see what happens:drink: I am seeing light at the end of the tunnel:party-smiley-048:
Rambunctious 09-03-2008 07:54 AM
awesome news Jeremy
you are smiling now right ??
we need video this next time.......
Ramb
Car Biz 09-04-2008 10:18 AM
Originally Posted by Rambunctious (Post 2672751)
awesome news Jeremy
Ramb
are you gonna be my camra guy:drink:
Rambunctious 09-06-2008 05:59 PM
got your message
haven't called back yet obviously. your post reminded me as i sit here sat night...sorry
I am busy this weekend, but will be boating to saugatucik thursday night if you want to join us
I'll be camera guy
Ramb
