-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   How do i get bad el footrest upp? (https://www.offshoreonly.com/forums/formula/194307-how-do-i-get-bad-el-footrest-upp.html)
502 Magnum 08-30-2008 04:26 PM
Hi,I`v got a Formula 303 SR1 with bad el footrest,annybody knows how to get theese white glasfiber things upp?Appreciate your help,thanks.
502 Magnum.
Magicfloat 08-30-2008 05:05 PM
Pry off the overlay(gray plastic,it's glued on)You will see some screws under there.Remove the screws and the fiberglass step lifts off,exposing the motor. BTW,many footrest problems are the result of a bad switch on the seat armrest,check it first.
502 Magnum 08-31-2008 03:58 AM
How do I get bad el footrest up
Thanks a lot Magicfloat, yes I will test out the switch first.
axapowell 09-02-2008 11:21 PM
Not to correct Magicfloat (cause He's always right....alright 98.5% of the time He's right) The 303 that I owned had carpet on the footrests, the screws were hard to see, but were in the carpet. Feel around for the flat head philips head screws. If I remember right, there were only 2 holding them on!
Dave
502 Magnum 09-03-2008 03:37 AM
How do I get bad El footrest upp
Yes,grey carpet on the footrest,I`ll look for the 2 screws,thanks Dave,it helps, I`m cleaning upp after sinking in fresh water,Its in a time like this you can see the difference from Formula to most other boats,this is quality,and yes I`m glad Magicfloat are here with all his know how,I begin to like Formula more and more,thanks again .
rjr 09-08-2008 03:02 PM
I pulled the gray mat on mine and saw pop rivets around about a 3" diameter hole. Are you guys saying that the pop rivets are holding the step to the motor and I need to drill them out to access the mechanism? The problem sounds like stripped gears
sleek1 11-19-2008 03:17 PM
Magicfloat,
are you saying the switch causes the motor to go bad or the switch itself may simply be bad? Reason I ask is one footrest does not work. I swapped the unaffected side (driver) switch with the bad side (port) and the port side still didn't work but the driver's side agiain worked fine. I could hear the relay working on the bad side (couldn't before the swap). Obviously I need to replace the port motor. Just need to know if I need to swap the old switch even though it appears to be functional? Sorry for the lengthy question.
sleek1 11-21-2008 04:18 PM
I got a dealer quote for a new motor-$600+. I wasn't expecting that, thought maybe $300. Anyone know where I might find one cheaper?
fastech 11-22-2008 06:48 PM
Sleek 1,
Try contacting stephanie mcleod at mccloed design group through there web site, www. mccleoddesigngroup.com. She quoted me a price of $350.00 for the foot actuator. They also sell any parts for bolster seats including the skins. Good luck.
sleek1 11-22-2008 11:12 PM
Thank you, I'll give them a call.
pshannon 11-23-2008 06:37 PM
Sorry this is a little off topic but, Sleek1 do you have a high res pic of your avatar? That pic looks awesome.
sleek1 11-24-2008 06:44 PM
Sorry, but I'm a tech idiot. I shot it with a digital camera. I'll see if I can goof around on the computer to get the resolution better. I think I can only adjust color, contrast, and one other thing (can't remember). Thanks for the kind words. I took that when my fiance and I were at Lake Powell last Sept. I don't think I can get enough resolution for a clear boob shot though.:drink: I do have some of the same pics posted in the Western US Section under my Powell Pics thread.
BowenCT 11-25-2008 09:22 AM
My '92 303 doesn't have the power footrests, but the set-up is the same, ie: the fiberglass steps are separate from the frames and covered with carpet and held in place with screws.
Is there a way for me to add motors to have power footrests?
