-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Wanted: 382 Dash Panel (https://www.offshoreonly.com/forums/formula/196939-wanted-382-dash-panel.html)
t500hps 10-08-2008 09:12 PM
Do I remember someone had made replacement dash panels for a 382. I have a custom panel that came from the previous owner. I'd like to make a new one. Removing a couple gauges I no longer need (boost gauges and fuel flow) and instead place the remaining gauges around a flush mounted Garmin 182C (that is currently a top mount).
Back4More 10-09-2008 07:30 PM
You could order the new the carbon fiber ones or save $1500 and have someone cut something out of 3/16 or 1/4 aluminum....BTW, I have access to CAD and CNC equipment.:rolleyes:
C_Spray 10-10-2008 07:12 AM
I believe that Nort Alderson (PhantomChaos) is your man.
fossil fuel 10-10-2008 06:15 PM
If you are going to all that expense replace the gps with garmins latest 545...way easier to see in direct sun
formula 382 sr-1 10-10-2008 10:14 PM
I may still have the old one, and I still have your DVD. :grinser010:
t500hps 10-10-2008 11:51 PM
I already have the 182C and I like it......the only expense should be the panel (and my time....need something to do this winter)
formula 382 sr-1 10-11-2008 04:09 PM
2 Attachment(s)
I had all our panels made at Norva Plastic in Norfolk Va @ $294.00 for 6 panels.
formula 382 sr-1 10-11-2008 04:12 PM
We are going to redo ours this winter and add water press. and oil temp. gauge's .
wildthing357 10-12-2008 07:53 AM
I have sheets of carbon fiber if you need a piece let me know the size and I will get the cost.
t500hps 10-12-2008 05:45 PM
Did they make the panels AND cut all the holes? Or just supply the panels? Maybe we can get both of them made at the same time....although I want a plain white one to match all the other panels since I'm not replacing them. (My dash panel was replaced once before to add spaces for boost gauges so doesn't match now.)
