-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Do I need to lift the engine out???? (https://www.offshoreonly.com/forums/formula/199320-do-i-need-lift-engine-out.html)
Monaco20 11-24-2008 06:10 PM
1 Attachment(s)
Do I need to lift the engine out to change to performance exhaust system ex Gill/Hardin or Revolution Performance exhaust???
I have a 242 SS 1988 with a 1997 454 330 hp stock exhaust
What is the best choice of performance exhaust system?
CP Performance Gill/Hardin system us 1999,- incl. full instalation pack. Should increase aprox 20 Hp and better torque. (Claimed by seller)
or
Revolution Marine Offshore performance exhaust us 1500,- include full instalation pack. Should increase aprox 30 -35 hp
Claimed by seller)
Innputs, oppiniones are appreciated
James 11-25-2008 06:25 AM
Pull the motor, makes it very easy to hang the new pipes, you can also check for other problems with a 1988 boat, check drive coupler for wear, check mounting hardware, replace your raw water pumps while it out , starter etc...- You will be happy you did
BowenCT 11-25-2008 09:26 AM
What James said makes sense, but to answer your question, no you do not need to lift the engine out.
Monaco20 11-25-2008 10:12 AM
Thanks for your reply, It is a good idea.
Monaco20 11-25-2008 10:13 AM
Thanks for the reply
Which exhaust system of the two would you go for??
BowenCT 11-25-2008 10:41 AM
I have the Gil set-ups on my motors and like them. I have a pic floating around somewhere, if I can find it I'll post it.
I don't know anything about the Revolution system.
Monaco20 11-25-2008 02:11 PM
3 Attachment(s)
Nice boat and dog you have :drink:
My boat and my dog are smaller than yours,:drink:
Both are nice though
Phazar454Mag 11-25-2008 03:56 PM
Are the claimed HP increase of 20-35 really true if changing to a performance exhaust system on a 330 HP ?
Do you want to change exhaust because the current exhaust is in a bad condition and it really needs to be replaced soon, or is the current exhaust in good condition and you only want to change to gain more power ?
Monaco20 11-25-2008 04:26 PM
2 Attachment(s)
Hi my Scandinavian nabor, how are you?
Well first question I realy do not know, if the increase is really true. I have been in contact with several suppliers and they all claim that there are around 20 - 40 hp gain by changing from stock to performance exhaust, depending on wich one u choose. Also that you get better torque and that crusing speed and top spedd should increase. But how mouch is hard to say, they have mentioned 2-4 mph but hard to say. The different performance exhaust are between 60 to 80 pounds lighter. (I have of course informed that my engine is 454 330 hp bravo 1)
I belive that my stock exhaust are more or less ok, but the exhoust gasket on the left side is broken. So it need to be changed, I realy do not the exact status of the manifoild and rasors.
I guess I would with my new Mirage 21 pluss would like to see
some more mph and power :ernaehrung004:
Pictures of hardin/gil and the revolution performance exhaust
masi242 11-25-2008 06:40 PM
I am not sure witch one I would go with but, remember you need to relocate your oil filter, shift interrupter and cables and anything else.
BowenCT 11-25-2008 06:55 PM
1 Attachment(s)
Here is a picture of my Gil set-ups. Same set-up as the one pictured in your post:
KEPP 11-26-2008 11:26 AM
First of all any cast aluminum exhaust manifold would be a great upgrade for your engine. We sell all popular performance manifolds like Gil / Hardin, IMCO, Stainless Marine and others. Gil marine has been in the exhaust industry for quite a while now and has been proven to be a performance manifold even my Mercury themselves. Gil exhaust was used on all popular HP500 model engines with great success. Gil manifolds incorporate individual internal runners for performance, powedercoated inside and out for durability, unique turbulator to help extend valve life by keeping condensation from entering the cylinder heads, and individual water ports to help prevent "hot spots" in the manifold. The kit you are looking at even includes a stainless steel riser and all install hardware needed for installation. Hope that helps, and let us know if we can help with anything else.
Thanks,
KEPP
pokerrunboats 12-01-2008 05:57 AM
1 Attachment(s)
I recommend the Dana exhaust
the results and gains of the large units are very similar to
CMI `s at half of the price
