-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   87' SR1 272 Exhaust Tips (https://www.offshoreonly.com/forums/formula/200779-87-sr1-272-exhaust-tips.html)
SR1kid 12-30-2008 10:27 AM
I have a 1987 SR1 272 with twin 350 mags. I am going to pull the silent thunder swim platform off this winter and put a aluminum platform on but i'm not sure what to do with the exhaust! has anyone done this before? What kind of exhaust tips have you used? Inner flapper or outter flapper? PICS?!
Thank you in advance!
zdek 12-30-2008 11:49 AM
I have dry pipes and have no trouble with water coming back in / over. I'm in Tulsa too and can give you a hand if you need.
Shoot me an email at joe.zaloudek(at)gmail.com
TylerBurich 12-30-2008 12:18 PM
1 Attachment(s)
Your boat should already have thru hull tips, but you will probably need the clamp on flappers just in case. I did mine last winter, a lot cleaner look! Also, the local noise police currently are after me....
Just make sure you have some help because that box will be heavy!
SR1kid 12-31-2008 12:22 PM
zdek- thanks man, i will email here soon.
captiva- I took the platform off last winter and put a new gasket seal around it because it was rattling! but i will look into the flappers just incase that way no wasps and other bugs crawl up in there to nest!
Thanks for all your help guys!
