I also had a 1986 f 35-7, and I have left 1 set of stainless marine exhaust that I never even tried... did they have stainless marine exhaust back in these days or they were newer exhaust ? maybe I could use them now????
Originally Posted by jeff32
(Post 2824086)
do you have a pictures of your current exhaust? I just want to see if your ''engine destroyer'' exhaust looks loke mine????
Also thinking switching for newer exhaust, for the affordable way... When I bought the boat, the damage was already done. Plus the water ports between the tail flange and risers were clogged with scale from 20 years of no maint. Gota have water flow thru the exhaust or the engines over heat. If you have the pre gils, change the gaskets. you can still buy them if you get a part # and google it. If you need it, I can get the part # for you. |
Originally Posted by poiuy10
(Post 2823934)
Coldsweat,
I basically did what you are doing, I went with the CMI's. here is my add on another site, to see the application. https://www.boatcrazy.com/search/details.php?id=468 see what you think, the original owner re-drilled the thru-transom higher as you can see its above the taco rail in the back. Good Luck ! |
If I were in your shoes, I'd buy a set of Stainless Marine manifolds/pipes. 5 year warranty. You can't go wrong with Stainless Marine, they make great power and last forever.
Kurt |
| All times are GMT -5. The time now is 01:11 PM. |
