-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Removing ST Exhaust Box From 1997 382 (https://www.offshoreonly.com/forums/formula/208221-removing-st-exhaust-box-1997-382-a.html)
DoczDock 05-05-2009 11:07 AM
I was getting ready to remove my ST box from a '97 382. I ordered the external rubber flappers for the tips but now I discovered that the internal flappers on the tips are gone. Will I need them both? The internal flapper brackets are riveted in and tough to get out. CP Performance has replacements but they look a little different. Any advice? Has anyone replaced these?
ThirdBird 05-05-2009 11:36 AM
If you get the good quality external flappers (don't remember the brand name) then you don't need the internal flappers. I think they are Salisbury flappers or something like that.
Magicfloat 05-05-2009 06:01 PM
Salisbury (sp) makes most of them,many are private label.Corsa,Mallory,etc. They all work fine
DoczDock 05-09-2009 05:03 PM
MagicFloat, I don't mean to beat a dead horse but are you saying that it would be ok to run with just the external flappers? I would like to be sure because it doesn't look like it is very easy to replace the internal flappers and I really don't want to do it if I don't have to. I have purchased rubber clamp on flappers from CP Performance. Thanks for your advice!
Magicfloat 05-10-2009 04:11 PM
You will be fine. The internal flappers were used by Formula because the ST box fills with water.With the box off,external flappers are all you need.
DoczDock 05-11-2009 02:07 PM
Thanks!!
