-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   382 fastech sling lifting (https://www.offshoreonly.com/forums/formula/208268-382-fastech-sling-lifting.html)
fossil fuel 05-05-2009 09:15 PM
Does anyone know if there are specific sling lifting guidelines for a 382. Lift points, foam blocks..ect
40gt 11-10-2014 05:09 PM
I know this is an old topic, but I need the answer as well.
I contacted Scott at Formula boats and this was his reply.
Now we all know.
Hi, Blaine,
We do not have a sling drawing for the 382 (nor for most of the boats we produce)—just put the aft one a few (2-3) feet forward of the transom, and the other just forward of where the windshield and deck meet, and you should be fine.
Thanks,
Scott
jeff32 11-10-2014 07:49 PM
That is exactly what i was doing with mine and it always went perfect with no surprise!
GL@PBC 11-11-2014 09:22 AM
That's where we would set yard arms to lift off a trailer, basically put the rear strap a foot or so from transom and the front strap where the windshield meets the deck and take it slow.
314joey 11-11-2014 09:28 AM
You mean like this, I had my 353 slung off when I brought it down South, seemed to work just fine, it did scare me to see the straps on the rub rail though, there's a lot of pressure on it.
VoodooRob 11-11-2014 10:03 AM
1 Attachment(s)
[ATTACH=CONFIG]532411[/ATTACH]
kevlar382 11-15-2014 07:39 AM
Your trailer is what decides where the straps go. It is a good idea to mark your boat so if you have to sling it out of the water you can match the gaps in the bunks of the trailer.
