-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Loadmaster Steel Trailer info (https://www.offshoreonly.com/forums/formula/213703-loadmaster-steel-trailer-info.html)
sdodson1 07-26-2009 07:12 PM
I have searched all over for info on 3 axle loadmaster trailers. I need brake parts and info on the spring setup. It is popping loud at the spring hangers and they are shifting back and forth. Never owned a trip axle and dont know if it just needs grease or bushings or its normal. It freaks my wife out and she is the one that usually launches and parks the trailer.
Thanks in advance!
Sean
ThirdBird 07-27-2009 06:27 AM
you probably need new hangers (theres a term for them, can't remember) and bolts. They do wear out. My previous tri-axle ground the bolts half-way through. Not good!!!
Oh, they're called equalizers.
duke252 07-28-2009 07:32 AM
(800) 258-6115
Call Gary Jr. Nice Guy, more than willing to help.
Interceptor 07-28-2009 08:47 AM
My Loadmaster makes the same noises when we pull up the ramp and transition to flat pavement. I've always thought it was sort of normal since it has doe this since day one.
Guess I need to take a closer look at all the links and spring etc..
ed
