Sink Drain?
I have a 98 271 fastech I am wondering if anyone out there is annoyed that the sink drains in the bilge? I am also wondering if anyone has changed the drain location to out the side like to older ones as I am thinking of doing this. Any advice?
Thanks |
My 242 is plumbed to the out side we don`t use it much. I am sure regulations made Formula do this. It`s and easy fix.
I called formula on this and they are tellin me that its a structual issue and dont do it. I dont see why it cant be done as the older ones have it a friend I know has a 97 271 same boat and his came like that with the drain out the side. I am just looking to see if anyone else has done this.
Structural issue ??? I don't understand that.
Thats what I dont understand hows it different from the older ones other than the step bottom!
Think mine drains into the bilge also, no biggey, why does it bother you?
Sink Drain
I'v got a 2000 / 271 never used the sink or chase the drain down but it is some thing I will be doing in the future Always thought it went to the holding tank. :confused:
Originally Posted by 88242LS
(Post 3016815)
No clue where the drain goes on my 303........never once used it.
My older 91' s9s was plumbed right out the port side. I would think the only thing you need to be aware of is locating the position so as to not go through the structural grid, other than that I can't see why it would be a problem. IMHO.
| All times are GMT -5. The time now is 06:02 PM. |
