FasTech Speaker Install Panels
Speaker Install in a 353...really wanted to maintain the factory panel look...but needed major upgrade on the sound!
What do you think? http://i887.photobucket.com/albums/a...l/HPIM1324.jpg http://i887.photobucket.com/albums/a...l/HPIM1325.jpg http://i887.photobucket.com/albums/a...l/HPIM1320.jpg |
Looks Great !!!!!!! :coolcowboy:
1 Attachment(s)
sweet.....did you make those panels beside the rear bench seat? I made some for my 382 but not nearly the same equipment.
2 Attachment(s)
Looks great!!!! You will be happy with the JL's.
Lil preview of my stereo install and new upholstery. I will be starting a post on this whole project soon. Total of 20 new JL's. |
Looks Good...You are rebuilding the whole area below the bench seat for the subs?..lotsa work!
I am beginning on the 292 right now (8) JL Audio 10" subs in the side, and (6)pair of M770 Components. Steve Tester at Formula has been a great help and has supplied me all exact match vinyls for the job....and Steve Dunham at Innotech is making Blue Carbon Fiber Panels to mount the 6 amplifieirs on in the cabin. Lotsa detail work, but it should be impressive!...now all I need is time! |
1 Attachment(s)
Originally Posted by laketravis
(Post 3036923)
t500, roughly what did the dash panels run. Also, check your PM I sent you one a week or so ago
Thanks |
Originally Posted by sdodson1
(Post 3036988)
Thanks I hadn't noticed a PM but will check for one. |
1 Attachment(s)
(Post 3036639)
What do you think? Dave |
Originally Posted by axapowell
(Post 3040094)
I think you are missing some custom made polished step plates!
Dave Your right...I am building an incredible Stereo / LED Lighting Package in a 292 and definetely need a pair....how do I get them? Tom |
I know this is an old post… any chance you have a template for those panels for the 382!?
thanks!
Originally Posted by t500hps
(Post 3036712)
Originally Posted by Rob Corley
(Post 4825271)
thanks! I don't have a template but you do. I removed the panel and traced the top of the old panel then measured the available space outward in each direction to fill the space that exists and traced the old panel along those dimensions. It ended up adding an inch or 2 in every direction. Then covered the panel with matching replacement material. |
| All times are GMT -5. The time now is 02:41 AM. |
