Formula 233 hull ID?
Bought a 23' formula today but the guy i got it from said it was a 1978, however the hull # is F2312188 Last i knew the last two digits were the year??? And does anyone know what the rest of the #s are? thanks
Originally Posted by starsnstripers
(Post 3062133)
Way back in the day, companies were pretty much free to make up serial numbers as they pleased, then they were standardized to the format you see today. I've seen serial numbers similar to yours, and I would say it is a valid number, probably from the '70s. Post a picture of your boat and I'll bet I can identify it.
Can't get a pic on here got an email i can send it to you? Thanks
Link to ad
http://maine.craigslist.org/boa/1631914472.html I have better pics if i can get your email boiler? pm it to me if you want
engine #s
the port engine #s stamped on the flat surface next to the distributer is at the top f 122 t under that 2nd # is 8317957 Stbd engine top 122 t 2nd # is F 8317960 It has the MC-1 drives with the eye on top of housing
Looks like that boat sat in the water check out the transom and stringers
That's NOT a 1988 model!!!!
Magicfloat might be able to identify it. |
Originally Posted by t500hps
(Post 3062912)
I know it's not an 88
My question is if it's a 1968 or 1978?
Ill guess a 1978
try this
(Post 3062964)
The windshield has changed over the years and although it is difficult to see from the pictures it appears to have those divided front windshields which the 233's only had around 1973-1975 (i.e., 2 window panes rather than the whole big ones used before and after). |
| All times are GMT -5. The time now is 08:56 PM. |
