changing gear oil in trs drives
found the dipstick for the gear oil but not the drain.
how do you drain the oil?? its a 1984 7.4 formula f302 borg warner trans and what gear oil should i use |
The drain for the trs outdrives is on the port side of the outdrives case at the very bottom. It is a straight screw head drain plug located on the torpedo shaped lower housing
As far as fluid I am running royal purple 75w90 gear oil. Each outdrive takes almost 4 quarts. Be prepared, the oil is a little pricey! $156 for a case (12 quarts) Make sure you purchase a merc fluid pump as they recommend you fill the drives from the drain hole to force any air bubbles out as your filling. Good luck! |
thanks again .. someone said to take the top cap off dump 3qts in there then fill the resovoir up.. which way is better?
I drain from bottom and remove cap to fill. Let it settlle and rotate prop shaft couple times to make sure all raped air is gone. Inspect large O ring on cap and put a little never seize back on bolts. dont overtighten. I use the Merc racing stuff I get in 5 gallon bucket. Good luck
Mike |
Drain and fill from bottom , don't forget to watch the reservior and aslo open it ..do not over fill .
To get all the air out ..hand rotate the shaft while filling in between some pumping !!!!!!!:party-smiley-004: |
Originally Posted by mookster
(Post 3128670)
thanks for the advice!
When I filled mine I filled from the bottom drain plug but also removed the drain plug near the top of the case. When fluid came out of this hole I knew I was close to full. I put the top plug back in and another 3/4 of a quart and she was full!
| All times are GMT -5. The time now is 08:37 PM. |
