-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   drive switch probeum (https://www.offshoreonly.com/forums/formula/234456-drive-switch-probeum.html)
towboss56 07-11-2010 12:48 PM
help anybody ever have problem with port side lower unit brovo 1. goes down with switch but but wont go up no power when tested. relays are good no power from black control box.also no power to trim on throttle. it will work if i jump power to switch. 2001 312 fastech
srl520 07-11-2010 07:26 PM
Make sure trim senders on the drive have power. Mine had corroded the wires. I could trim down, but had to use the trailer out switches to get the drives to go back up.
88242LS 07-11-2010 09:11 PM
my wire broke last year thats also what I have to do
towboss56 07-17-2010 01:24 PM
thanks ill try connection
