-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Internal Platform Flappers - 88 242LS (https://www.offshoreonly.com/forums/formula/234525-internal-platform-flappers-88-242ls.html)
formula206ls 07-12-2010 12:29 PM
All,
I think the previous owner may have removed the internal flappers from inside the swim platform. Are they necessary? Do they serve a purpose?
Thanks,
Peter
masi242 07-12-2010 07:50 PM
No you should be fine ,most of the older boats most likely burnt off over the years the swimplatform will work as you baffle.
formula206ls 07-13-2010 10:49 AM
Thanks Masi. My concern is that the internal platform baffles will prevent water from being sucked back in or flowing back in through the exhaust? Should I be concerned with that?
masi242 07-13-2010 03:23 PM
The chamber inside the platform is big and has drains,only so much water can flow thru the rectangle exhaust to back flow.
