Docking Light
Anybody got a Morse docking light for a early 90s Formula kicken around. I need just the sealed bulb and enclosure with the two wires sticking out of it. Thanks
I took mine apart and replaced the seal beam with fog light bulbs from autozone.
Thanks for the info,gonna try that same thing, wanted another one on hand just in case it gets destroyed in the process. This is the newer style without the ring holding the two halfes together. It looks reccesed into its self about a 3/4'' and glued, so it aint gonna be pretty when its over. Thanks again.
The plastic is more plyable than it looks. I used a thin blade screwdriver to work in and under where the two halfs are put together. A little sealant to put back together and it looked factory. Oh, work on a folded towel.
| All times are GMT -5. The time now is 10:17 AM. |
