-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   330 SS repower or... (https://www.offshoreonly.com/forums/formula/235516-330-ss-repower.html)
hq_ 07-26-2010 10:04 AM
330 SS - INSANE repower?
I've been lurking here for a while, gathering valuable information for my next boat purchase. Now there's something I'd like to hear people's (expert?) opinions about.
I'm about to purchase a 330SS, a clean boat, 454/330 MPI:s with low hours but maintenance has clearly been neglected. The problem is that there's some evidence of rust and freezing damage in engines - repower time. I'm considering twin 475...525hp, possibly even more.
o How much power can the 330 hull handle?
o How much can the drives (Bravo 3) handle in a boat this size and what are my options with props, assuming that I keep the drives?
o What other factors should I consider, trying to keep the amount of components to be changed at a bare minimum?
o Anyone broken 65 or even 70mph with a 330SS... yet? :D
Mentalpause 07-27-2010 08:55 AM
I don't think Formula would put more than the 375 hp 496 in them. There is a reason for that.
Ted G 07-27-2010 09:05 AM
o How much power can the 330 hull handle? Probably quite a bit, but because of the wider hull it is not really an offshore hull like a sport Formula. They ride differently and tend to pound more so at high speeds you would be looking for flat water.
o How much can the drives (Bravo 3) handle in a boat this size and what are my options with props, assuming that I keep the drives? This could limit you, there is a supposed maximum speed to Bravo 3's just because of props available and dragging all that stuff through the water, you would need XR's to really go fast.
o What other factors should I consider, trying to keep the amount of components to be changed at a bare minimum? There is a lot of stuff in that cabin, if you go out and thrash it like an offshore boat it will eventually uninstall some of that stuff. Although Formula build quality is quite good so you are probably better off than some "Express Cruisers".
o Anyone broken 65 or even 70mph with a 330SS... yet? Dunno, my buddy's does close to 60 with 496s and Volvos. :D
Otherwise it is a great party boat and with a reasonable 40-50 mph high cruise, but if you boat where it's rough you might want to test drive one first.
Mentalpause 07-27-2010 09:11 AM
Those are the reasons. Plus at a certain point that hull just won't go much faster.
Ted G 07-27-2010 09:18 AM
Come on, if it's pointy at one end we can make it go faster, just need enough power, probably get over 100 with 1200s :D :D
88242LS 07-27-2010 01:07 PM
whats speed does the 330 run with the 454/330??
t500hps 07-27-2010 01:27 PM
I've heard it's a PIG with the 454/330's......BIII are regular bravos with a lower that gets a much better bite on the water (dual props). 500hp should be fine in that boat if driven like a little old lady is on board, and should hit mid-upper 60's once the props are tuned for it. (BIII will limit speed eventually but this package wont be fast enough to make a difference). If you like the rest of the boat look for 496/425 take-outs or if willing, tired 500's and re-fresh.
hq_ 07-27-2010 05:02 PM
Thanks for input, this sounds like a good start.
Most of the water the boat will see is archipelago, no chop to speak of and I fully understand that we're not talking about an offshore race hull here. (Deadrise... 20deg?) I also understand that at high speeds that hull can get you in a lot of trouble if the driver doesn't know what he's doing.
A family man has to compromise between speed, size/maneuverability and room to keep wife and kids happy.
I think the stock 454/330:s are good for low 50's mph or something like that, which is IMO borderline pathetic for a boat that's supposed to have some performance. 60mph+, preferrably high 60's or 70mph flat would be just the ticket.
If twin 500's or so will suffice for that, I'm happy. Delta Performance's 600hp QSB diesels and surface drives is a high-$ alternative, that can't really be justified with estimated 40-50hrs a season.
patmccoy 11-01-2012 10:10 PM
My wife and I purchased a 2000 330SS about 6 years ago. I got a good deal on a pair of Bravo1's that I had installed. Boat went about 52.
A few years later we rebuilt the 454's into 489's. This got us to about 58.
Next we got a great deal on tips and diverters. That got us another .2 mph no the gps.
Next I took out some of the wedge on the bottom that gave us about 1 or 2 mph.
Next we installed some CMI headers. So far we are at about 59.4 if I remember correctly what the gps said.
There are some friends at the marina with the same year 454's. They ran some ethanal fuel as I did. The fuel lins are breaking down so they were replaced and it inproved the function of the motors. I plan on doing the same thing this coming spring.
I know this sounds like we should have purchased something different some time ago, however it is a bit fun working on the project. We like talking about it and making noise.
Knot 4 Me 11-02-2012 07:36 AM
If high 60's to low 70's is your goal you really need to look for a different boat. The HP it will take to run that hull those speeds will be busting those Bravo III's left and right. Even if you can keep the drives together you start to run into cavitation burn on Bravo III prop sets at those HP levels and speeds.
aquaforce 11-02-2012 07:54 AM
The 400SS has some 525/B3 or XR packages that will push it to 60+. If you ran the same thing in the 330 the performance would be good but there is a bunch of money needed for that. Some take out packages would help the price but a a lot of things to consider in dollars to donuts.
That is a good boat still and good luck with your Formula interest.
