Gaffrig GPS
Noticed Yesterday the Gaffrig GPS did not work in my 353 ...has been fine up til now ...( since June) .....I was running my Garmin GPS up on the dash .....Could there be a conflict between the Garmin GPS and the Gaffrig Unit? .......m
Most likely the battery in the puck (GPS Antenna) went bad.
Originally Posted by Sonic Steve
(Post 3200055)
There is a thread on here about hooking the speedo to your GPS. If your speedo needle is settled at about 20 mph, it has no GPS signal, that can be remedied by hooking to the NMEA output from your GPS.
Originally Posted by Ted G
(Post 3200136)
http://www.livorsi.com/catalog/gps_antenna.htm I might just remove the Analog Speedo and Flush Mount a GPS between the tacts .....m |
| All times are GMT -5. The time now is 12:55 PM. |
