-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   303 headliner (https://www.offshoreonly.com/forums/formula/247114-303-headliner.html)
Secretformula 02-06-2011 02:10 PM
303 headliner
I'm going to replace the headliner and sideliner in the bunk area of my 1995 303sr1. How do I remove the valance boards where the hull sides meet the underside of the deck? I have already done the cabin but this seams to be different. Thanks.
Jeff H 02-08-2011 09:02 PM
Not a fun Job. remove the lights on the sides (phillips screws), then you can reach behind the valences they are thru bolted with poly nuts.
dont know if you can get a 1/4" drive air rachet behind there if you can it would speed up the removal. the studs were long on mine.
Jeff
