Outdrive Issue
Long story short...I hit the outdrive switch up and the drive moves up. I click the switch down the motor runs but the drives wont go down. Suggestions?
Piston is probably sticking try have someone stand on while u work up down. That usually fixes them
Originally Posted by ur2slow
(Post 3374326)
Check Trim Pump
Originally Posted by jiffy292
(Post 3380841)
Check Trim Pump
This has happenned on a few of my boats. It's usually from corrosion on the switch that accumulates during storage.
There are trim pumps in the engine compartment that supply hydrualics to the outdrive trim rams. They have a solenoid that controls up and a solenoid that controls down. The solenoids do go bad. Your boat is just the right age to lose one as well. It's not a hard fix.
Fixx
crack the lines at the pump, if fluid comes out of the lines and the drive goes down but you may have to push down on it them the problem lies in the pump,if its still stuck solid then their are issues with the rams..
Originally Posted by Sydwayz
(Post 3380971)
Originally Posted by Gladhe8er
(Post 3380967)
Originally Posted by mrfixxall
(Post 3380973)
use jumper wire to jump pump to check i believe blue wire is up green is down
Not to be a $hit but did you check the fluid level
Originally Posted by sprink58
(Post 3383943)
(Post 3383651)
| All times are GMT -5. The time now is 09:37 PM. |
