No start... Not even a noise
Here's the situation: '81 233LS, OMC 260 (chevy 350), stringer 800 outdrive, single interstate marine battery. Bought the boat in Jan. Went to fire it for the first time this morning after charging the battery for 24hrs. All systems came online, lights, gauges, outdrive trim works, etc. But not a single sound from the motor. No crank, click, or anything... Does the boat have a safety other than the key? Is there a fuse I'm missing that would commonly be out? Is this a typical symptom? Someone wiser than me chime in please!!
Originally Posted by machloosy
(Post 3375599)
even slightly in gear. |
I'm not a boat mechanic but I have a boat so I know a little bit. Make sure the safety lanyard is on good if the boat has one, make sure the battery connections are clean and tight, could be neutral safety switch jiggle the shifter while trying to start it. good luck
I love OSO!!!! You guys rock. Thanks Jus
Boat hasn't been run in almost 7mon and I bought it sight unseen without knowing if the motor was good. A little choke and she lit off faster than any boat I've ever seen on ancient Gas. I love chevy motors!!!
(Post 3375631)
(Post 3375634)
Well seeing I've never had this one running it was awesome. Carb needs rebuild badly though. Should be a fun time and hopefully next thursday she'll see water
| All times are GMT -5. The time now is 11:16 PM. |
